190E 1.8 1992 Auto stalling intermittantly after slowing down and only in low gears. Fuel pump relay, Voltage protention relay, Fuel pump & filter as well as Ignition leads, Cap & Plugs are new. Where to from here??
Ramius said:Just had a similar problem on mine (300te24)
Tried many things, the biggest recommendation was fuel filter being clogged. After a trip to a local specialist, the removal of the bellhousing and a good clean of the butterfly on the inlet manifold it again idles like a dream. So for me it was a build up of general muck!
(not a disclaimer but my technical terms and names for parts may not be the exact ones! (im sure he said bellhousing!))
I have done all of the above but still have the problem. Has anyone had problems with the speed sensor on the bellhousing??kit820 said:Indeed the fuel filter would be the prime suspect.
haido1 said:Paul,
idling smoothly & to specs. Cold start, warm-up and load compensation all okay. Is there a speed input for the idle solenoid power supply??
