R
rjsdavis
Thanks for all those that have assisted me with the other little problems that I have had with my 190!
At the moment, whenever I start my 190E, she starts first time, however, she does suffer from a brief fuel supply problem - this is particularly prevalent after she has been parked up overnight.
She will start first time, but I need to dap the throttle to prevent her from cutting out. Immediately after starting, she needs me to keep my foot on the throttle for about 10 secs, whilst she appears to be cleaning out a blockage in the fuel line. The rev counter and engine noise indicates that the fuel is not getting into the engine as it should, and she will not go above about 2,000 rpm for the first few secs...
After about 5-10 secs - this is cleared and she will rev and appears to tick over normally.
However, as you are driving her - for the first ten minutes or so of driving, she is still suffering some slight fuel problem. As you pull away from stationary, she has not got full power available to her (not that I am looking for quick starts), and you can feel her struggling to get the fuel into the engine.
After about 7-10 minutes of driving - the problem disappears (when she is running at normal engine temperature). If she is parked up for a few hours during the day - the problem will return, but again only until she is back up to normal operating temperture.
Can someone please help me identify what problems to check for as I am no expert mechanic, and could really do with a little guidance with this.
Thanks alot.
Richard
Thanks alot.
Richard
