Hi everyone,
Its a facelift W202 and a few niggles that im trying to sort out...
Firstly when the radio is on and the rear screen demister is turned on the radio instantly cuts out and only static is heard. I know the aeial runs down on the rear, the two strips but not sure why the demister would interfere? Any ideas anyone?
Secondly the heater control has a bulb gone. Now what is the easiest way to change the bulb on these. Pulling the bulb off i dont think will give me access. Will the trim panel have to be lifted off and the heater control unit unscrewed out and the bulb changed like that?
Finally on the heater control fan speed knob on other 202s the 0 setting switches the fan off and closes the vents, then after that there is the setting which opens the vents but the fan stays off and then 1-5 which turn the blower motor on at different speeds. For some reason the blower motor switches on and runs on the setting after 0 which im sue should just open the vents for air but not turn on the fan. Am i right?
Many Thanks in advance
