w202 abs light on
hunter-haken
cheltenham
c250/1999/2.5td
Hi all I have a 1999 w202 c250 , iv had it almost a year and the abs light has always been on how ever its cumming up for mot time so figure I really should sort it out
My question is , is there a way I can read the fault code with out taking it in to a garage have been looking at the obd code readers and merc adapter cables but these all seem to say they read engine codes and don't mention abs faults , I know with some older cars you can rig up a test light and count the flash codes
Basicly the abs light is perminantly on abs doesn't kick in , brake lights work , cruise control works
Any hints or tips for finding out what's causing it or ways to reset the fault would.be greatly appreciated cheers Andy
You should be able to get some read out on STAR for that fault, as the CC works it could be a rear wheel sensor
H
hunter-haken
cheltenham
c250/1999/2.5td
Thanks thinking about it its always the rear off side wheel that spins abit when pulling away , isn't star the dealer dig kit ? Hoping to find away of diag'ing it that I can afford lol
Thanks for the advice
An indie should not be very expensive, cheaper than buying even a cheap code reader
brandwooddixon
Wolverhampton
S63 Coupe 2014
An independent Merc specialist will charge around £65 to get the codes read. Some don't charge for a STAR diagnostic if they also do the work.
You're based in Cheltenham?
