W202 ABS Pump wiring diagram Required...
silestanix
London!
03' BMW 325Ci
Evening all, so I've recently started having issues with my ABS. Went to WG-MB and STAR said front passenger side abs sensor.
So this has been replaced with a new item however the light still comes up randomly during a drive and stays on.
So yesterday when I went to have the rear shocks and subframe bushes done (LONG and Arduous job, fair play to Jamie, patience of a Saint), Jamie also cleaned the ABS ring (took ages, did it by hand, each tooth) and the new sensor for good measure. The light unfortunately came back in a short while later... So I spoke to Terry and on his advice I have done some resistance tests on the sensor and all is ok, as well as the voltage increasing when the wheel is moved.
So now I want to test the harness from ABS Pump unit to wheel sensor... And this is where I need your help with a diagram of the ABS Pump wiring so I can see which pins I need.
Thank you...!
Harry.
om613
london
S202 C250TD, S123 240TD
I've got 2 W202 manuals you can borrow.
A Haynes and a German one ('So wird's gemacht') which has good schematics.
silestanix
silestanix
London!
03' BMW 325Ci
Got the Haynes one bud but useless, but can I borrow the German one? Cheers!
om613
london
Sure, no probs.
New language skills ;)for 2018, too!
