W202 blower only works on 2nd stage of ign
bigjobby01
Hi guys, I have had a problem with my heater motor where sometimes when I started the car the heater blower wouldn't come on. If I turned the engine off then restarted the car it would run.
The fault seems to have turned into the blower not running at all when the engine is running. If I turn to 2nd stage of ignition the fan works fine and controls, as soon as the engine is started, the fans stops until you put it back to 2nd stage again???
TIA
