W202 C Class Central Locking Problems
J22GLE
essex
ive got a problem with my central locking, ive lost the remote keys, im using the master keys,
the central locking worked with the passenger side door until last night, i tried to open the driver door and only the driver door opened, i then tried the passenger door and the boot along with the central locking switch on the dash, nothing happened, the fuel filler cap was still locked, i used the manual pull in the boot to open it,
now the keys wont open the driver door and i have to open everything else individually:confused:
im guessing the relay or the pump im not a mechanic and im going on holiday tomarrow to ireland it's a long way to drive plus the car can be easily broken in to now
!!can anybody help!!... thanks...
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
you mention 'master keys' what on earth is that ? a key with no remote capabilities ? please confirm
if you still have access to a remote key then look at this post.
http://forums.mercedesclub.org.uk/showthread.php?t=26895
all you may have to do is resync the key, or replace its batteries and then resync (scroll to the bottom for that info)
alternatively if only one door is opening at a time you may have a vacuum tube loose somewhere as the 4 doors (plus boot and petrol cover) are all linked together via vacuum
cheers
anyweb
J22GLE
essex
thanks buddy,
ive lost the remote keys, the master keys are the keys i got with the car along with the remote ones that open all the doors, glovebox and boot...
ill have to check the vaccum hoses when i get to ireland im leaving in a few hrs and need to go to bed...
thanks
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
a common area for the vacuum hoses to come undone is the headlights or somewhere in or around the vacuum pump itself (usually located in the back seat passengers footwell)
let us know how you get on
cheers
anyweb
