W202 Cruise Control
single650
My C200 has started dropping out of cruise :confused:
Is this a common fault?
Is there a simple fix - my suspicion is the brake switch
Ta
Nigel
wireman
lancashire
The brake switch on some models is a dual device, one for the stop lamps and one for the electronics, they are prone to failiure and quite cheap from MB.
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
Ta
Nigel
Welcome to the Forum.
Have you recently had new tyres fitted? If you have, then check they are the correct 'spec' for the vehicle. I had the same problem, which turned out to be as I described. The difference in rolling resistance, caused the c/c to disengage.
If not the tyres - then check the other postings for brake switch etc.
