w202 gearknob and gaiter
norton
Hi, I am new to the forum as I have just bought a C200Elegance Estate (1999), seems u call it a w202!.Anyhow, first thing to replace is the gear knob as it is disintergrating! BUT the knob and gaiter are ONE piece. Is it easy to change provided I can find one, as e bay shows knobs only?. many thanks and a great forum.
D
doversole
Good morning, Malcolm.
Yes, you are correct with the collet.
However, I believe Norton is referring to a manual 'box.
I don't have any experience with manual gearlevers, Norton.
However, i'm sure there will be some constructive feedback on the subject in due course.
Welcome from me, also.
DoverSole
N
norton
Reply
appreciate quick replies from Dover sole and Martin.It is a manual and the knob/gaiter def one complete piece. kind regards
PS DO live in SW but 1st march like Buses, everything comes at once ,hope to make yr next meet.Txs
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Pull the gaiter free from the trim panel by pulling it from one corner this will release it, pull the gaiter up over the gear knob as far as possible and you will see a collet ring at the bottom of the actual gear knob, turn this through 90 degrees (i think) the gear knob should then be released, it maybe quite hard to remove, a twisting pulling action may make it easier to release it.
Some have a grub screw holding them on
