richip
I would really appreciate some help as my patience and bank balance are rapidly running-out.
I have a year 2000 C220 CDi Sport that has now done 196K miles. Up till recently it has been a paragon of reliability. I travel all over the UK and the car has been nothing short of excellent.
Unfortunately it has recently developed two problems that I assume are related, although I'm happy to be proved wrong. The first is that the car goes in to the dreaded 'limp home mode.' I have had the mass air sensor, pressure control sensor, high pressure fuel pump and a leaky injector changed but still have the problem. The fault codes seem to change - when you fix one another appears.
The second issue is that the car started to cut-out, usually after slowing down following prolonged high-speed driving. The top of motorway slip-roads was a favourite place, although the outside lane of the M6 was certainly the scariest. The fault has now evolved and the car will stall after being restarted. In both events it takes a number of minutes to restart.
I know similar problems have been referred to on this site, but nobody seems to have had the misfortune to experience them both at the same time.
Any help would be hugely appreciated. I'm a huge Merc fan and also run a 107 500SL but I'm starting to lose the faith.
Richip.
Richip.
