W202 Main beam not working
saz7159
Hopefully a quick one for you.
The main beam on my 1995 c200 is not working, can push the lever forward but nothing happens. However the flasher is working when I flick backward, mean beams come on.
Since I cannot hear any relay clicking, I'm pressuming that this is the problem.
Here's where you can help me, where is the relay, is it a single use or mutlipurpose one? Or indeed, could it be a fuse, if so, where should I look?
thanks
BlackC55
South coast
C43
Combination switch will probably be the problem (indicator stalk) Get a second hand one and have a go at fitting it yourself
