W202 Seat Cover Stuck halfway through Removal
tjamesbo
Sutton Coldfield, West Midlands
1999 CLK430, 2007 VITO 3.0V6 , W124's (1994 320TE , 1993 220TE ) , 07 2.5 X-Type
Firstly its the backrest cover I am renewing as the Bolster had gone threadbare It was all going so well following the instructions Malc sent Seat out , trim off, Knobs levers off , Bottom half unclipped as per piccie below
Malc the instructions I have from you only cover the seat removal and the Base not the Backrest Bit which is where I am stuck
The problem relates to the next bits
Headrest trim how do these come out ?
and the trim at the top tucked in how does it come out see below
Boyd
I will see if there are some more instructions
T
tjamesbo
Thanks malcolm I have the headrest trim off now its just the top bit where it tucks in at the back
Boyd
OK I have it for you,,,I have a new computer so I need your address again as all got lost
T
tjamesbo
Thanks Malcolm its ************@******* now removed
Cheers Boyd
And sent you can edit out :D:D
T
tjamesbo
OK Thanks I have it now and its off the frame :):):)
T
tjamesbo
I have won !
after much prying of clips and wires The whole lot is off :D
Into a gentle wash for the Base and Air Dry Now onto the Waeco heated seats base & Back elements going in on the rebuild.
phil.dyke
hi, i have a similar problem, i'm trying to remove the passenger seat cover to repair the stitching on my 2000 clk. i've got most of the clips etc off ok but am struggling with the plastic guides for the headrest which i can't remove and therefore can't get the cover off.
its a leather cover and has elactric headrests.
any help greatly appreciated.
cheers
phil
Would you like the info that I sent :D:D
I cannot do this until tomorrow :( please remind me
Tyler Durden
New Registration
california
95 c280
Could you please send me this info as well...im having the same troubles for both the removal of the headrest and the top of the seat... everything else has been properly removed! Just two more steps and I with have this seat cover off!
Thanks!
unclebonesaw@gmail.com
