W202 Wheel Designs.
EDX
Essex/Suffolk border.
2009, C220 CDI, SE Blue Efficiency, Estate
I've been looking on the Russian site and found that the 6 hole alloy part no. A208 401 05 02 has been replaced
by part no. B 6 6 47 0523.
Are these from different manufacturers but identical in appearance or are they completely different?
My problem is, I've got 2 of the A208 401 05 02 wheels and I want to make a set of 4 so I don't want to go buying
the other type if they look different.
TIA
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
If it says its been replaced it will be identical, either number will be ok for your set.
Same or different manufacturer they will be identical if they carry that pt no
Put 2 one side and 2 the other, you cant see both sides at once :D:D
