W202 won't run but starts
W202
Hi has anyone on here had a problem running the w202 I brought it as a project if you turn the key to prime 7-8 times then start it will run for a few seconds then it's fuel starvation and stalls, the pump seems to priming okay there's pressure at the rails and I've swapped the fuel pressure regulator just in case.... What would my next steps be for trying I own a few w202s I took the relay out put it in another car and it runs fine so can't be the relay, thanks in advance :)
Danny phillips
W202
It's a c180 the car starts for a few seconds on prime thou so didn't think immobiliser it's a 1996 I'm going to take the fuel pump off my c200 and fit it to the c180 see if it's the fuel pump as mine is quiet noisy on the prime
om613
london
S202 C250TD, S123 240TD
OK, I was thinking if it was a 220 cdi it could be air (o ring failure in the fuel pipes).
Could be the pump, then.
I've got a whole '98 C200 / M111, if you need parts.
Danny phillips
W202
Okay mate thanks I'll try and swap my pump over if it is the pump I'll definitely be interested In yours I'll be in touch shortly :)
What pressure do you have at the rail?
Danny phillips
W202
When I take the valve off and squirt it, it sprays to about the wing there's pressure there but my other car shoots a lot further but that's a 230k
Danny phillips
W202
Also took pump off and same problem so can't be the pump dunno what else to try it's sparking fine as it runs when primed a few times it starts idles for a few seconds then won't start again till you prime it
Fuel supply issue. Probably blocked filter?
Not seen "wing spray" as an fuel pressure spec before :p. Is the pump running whilst cranking?
Danny phillips
W202
I took the pump off mine fitted it and wouldn't start till I primed it 1st it sounded promising but the stalled and wouldn't start again and haha its a good spec to use :p my other car squirt past the wing and I'll have to ask my misses to come out while I crank it as can't really here it while turning over but priming it for some reason sounds really loud louder then my other two I even put more fresh fuel in as car has been sitting a while
Oldspanners
Normandy
C CLASS 2004 C180
What about the fuel filter has it been changed?
Danny phillips
W202
I'm going to Parkers tommorow and buy a fuel filter as its a sealed unit I didn't want to take it off the one that's running only swapped the pump itself so could well be filter but won't find out till tomorrow fingers crossed
Oldspanners
Normandy
C CLASS 2004 C180
I don't know if your car has a metal tank but if the cars been sitting around I'd check the outlet from the tank for fuel flow in case there is some restriction.
Danny phillips
W202
It's been sitting around 4-5 months mate as I was working on the other one I did have a mechanic called out to it and he said timing chain has stretched but surly not as its low miles 67000 I believe plus it does start after priming I don't know the guy properly so I don't know if he is trying to have me on a new timing chain just to get money out off me if it had stretched would it still start on being primed I still think it's down to fuel as it does run
If it starts and runs with easy start or brake cleaner you can confirm the rest is OK.
Danny phillips
W202
  • #17
With easy start it does start up after spraying plugs and airbox I think because I'm young he tried to earn a few quid off me I'll buy a filter tommorow haven't got anything to lose hopefully it starts up
It's an M111 - timing chains don't stretch on them as it's a full duplex chain unlike the M271 that superceded it.
Danny phillips
W202
  • #19
Thanks that's good to know next time the mechanic drives by I'll show him the message you put
www.ckinsurance.co.uk
