Liam Stewart
- Oct 9, 2018
- W203 2007 C220 sport A CDI
Hello everyone, I have a RHD 2007 c class estate, 220cdi 150hp, with the 5 speed 722.699 automatic transmission. It has sport, cruise and manual driving modes.
Abs front right signal was faulty abs light on, so replaced sensor ring, badly corroded backing plate and abs sensor.
Had historic rear left Abs sensor code also
Replaced disk backing plate and cleaned on front left also.
Abs signals now good, warning lights gone/ cleared
engine management light on
No limp mode. Car drives but on an up gradient it goes through the gears quickly with a lack of revs and power.
I have reset the transmission and removed the fault with the icarsoft reader
Tried switching to sport mode,
Have had intermittent results, works briefly then engine management light comes on again with a lack of power in gears and going up the gears too quick. I can use the paddles to go down and up the box to make do.
I’ve renewed the transmission control unit
Resistance checked the solenoids (varied between 2.5 and 7 ohms).
Changed the transmission oil filter and renewed the oil, (it was dirty but still a bit pink).
test drove after clearing the EM warning light and resetting transmission again.
Same problem but drove a bit better especially on level or downhill. Drove 5 miles Switched to sport mode, got really good power but immediately Engine management light came on and sport mode deactivated. Back to the same problem.
I’m thinking it’s something at the transmission control module and I want to check the solenoids again without dismantling.
Do you know where the TCM is on the car please and any help with electrical fault finding is greatly appreciated.
Regards
Liam Stewart, Fife, Scotland
Regards
