w203 2.7cdi
sanpaule
w203 2.7cdi 2002
Hello i have a problem to start engine when it`s hot.when it`s cold stars perfect.engine works
without problems.thank you
CPS probably , this is a common issue
Oh and welcome to the forums
A.J.
Norwich. UK
Hi sanpaule, can't help with the technical issues but welcome to the forum :)
umblecumbuz
Wales and Gozo
You'll only get guesses without more info.
But for starters, as John says, it could be the Crank Position Sensor (CPS), because as they age they tend to go open circuit when they get warm, and restore continuity when they cool down - although it could be anything, from water build up in the diesel separator to faulty electronics elsewhere. Even where you habitually park (facing uphill may allow fuel run back if the fuel line O rings are getting hard, and leak).
The CPS is a sensible place to start checking. But - If there are no dash warning lights showing (and with a faulty CPS you may not get any lights) first visit a good indie and get the codes read. It will save you a lot of grief, time and expense in the long run.
And welcome. There are a lot of good blokes here, who have knowledge and can be very helpful.
sanpaule
w203 2.7cdi 2002
there are no leaks or warning lights.thank you
www.ckinsurance.co.uk
