hofnerpres1
- Sep 23, 2013
- Location
- Buxton
- CLK 2006 A209 Kompressor
Here's a good one for the Guru's and hopefully somebody else can learn from my journey. I swopped battling with rusty old classics to risk the electronic minefield of the "Modern Classic". Found a 2006 CLK C200 Komp which had spent it's life in a heated garage - 65K and mint. The EIS and that EZL had just been replaced so that was a bullet dodged. It managed less than a thousand miles before it was doing the intermittent stranded car horror show. Got the new EIS tested - all seemed good again - few trips later - no crank. ECU, Front SAM and EIS went away to be checked out. The rebuild company got Covid - also got baffled - 8 weeks later back together and another few happy trips. By now I had got up to speed with CAN BUS language and had traced the fault to a failure to pull down the starter relay coil leg to earth on the violet and white wire. The fault returned three counties away but by giving the starter a feed we got home. If this was a daily driver and not a retired man's toy I would have happily drove it off a cliff but it's an amusing puzzle which has convinced me that post 1990 classics are old computers and most will suffer the same fate. So guys. here's the challenge :
Permanent fault - car lights up - no fault lights - No Crank
Starter relay is not being activated by the ECU - bias voltage at the coil instead of being earthed. Power showing at the SAM circuits and all fuses good. I found a spare SAM - same car and part number for beer money so did a swap - same result.
EIS is new and has been tested again twice by two different companies. EZL is new (what a cheap nasty motor unit that is ! ) It works.
It's an Auto. Lever Module has been also tested as good and shows good switching and start enable on the scanner (iCarsoft MB)
Transmission Module also scans well - start enable working. Battery is brand new.
When 12v supplied direct to the starter - she jumps into life and drives wonderfully with NO WARNING LIGHTS and everything functioning.
The fun bit. At the CAN B lines at the OBD port we get CAN H zero volts and CAN L at 0.020 volts in all key positions. Does the diagnostic module block this ? The scanner seems also baffled since that is failing to link with anything other than the ECU and the TCM.
At the CAN B junction X30/4 RHS sill well we get happy readings - 11v and 4.5v with everything clean and bright at X30/7 as well.
I'm struggling for a wiring diagram - the downloaded workshop manuals are a very good example of the electronics world - all looks good but often crashes.
Over to you team..
Over to you team..
