W203 Brake disc thickness
Nuclear Bob
Lake District
Greetings all,
Please can anyone tell me the minimum operating thickness of both front and rear discs? (W203 C220 CDI coupe 2002). Interestingly still around 4 mm on the front pads - both pads and front discs replaced 4 years ago at 49000 miles (previous owner). Now 161000 miles. Rear discs and pads replaced 2 years ago - little wear apparent on both. I wonder what effect washing the wheels has on disc wear - a thin film of rust naturally appears on the shiny part of the wet disc until the car is driven again the next day - this is of course steel from the disc!
I need the next 3 number after 203 to tell you
delboy777
KEITH, MORAYSHIRE
2001 W203, 220CDI Elegance Full Leather/Sat Nav
Malcom, my next nos are 006, what would the dimention need to be, front and rear mine look a little worn but they maybe ok.
I have sent you the paper del,,its easier and quicker
Details sent Bob :D
rf065
Grossbritannien
I've just bought front discs & if you look at the leading edge of the discs, there is a flat spot machined on the inside of each leading edge at one position on each disc (vented discs). I assume that is a wear indicator, when the disc wears down to this point it shows they should be replaced.
Hard to explain , but if you had a new disc in front of you it would make sense.
http://i258.photobucket.com/albums/hh242/rf065/DSCF0110.jpg
http://i258.photobucket.com/albums/hh242/rf065/DSCF0111.jpg
Russ
N
Nuclear Bob
Lake District
Many thanks folks - I'll get the micrometer on to it - 22.4mm min. Looked at the flat spot - difficult to tell with the rust on the leading edge, but will remove and double check
HelpThisDude
Essex
W203 C270CDI, R172 SLK55 AMG
Malcom, could you help me with the min disc thickness front and rear?
W203 C270cdi 2001- WDB203016
Cheers buddy
With an Email address yes
