Hi, I am looking for some info and advice on changing the brake fluid on my 2003 C220CDI (W203) estate.
I also intend changing the front disc pads at the same time, looking at the posts this looks pretty straight forward. (I have already bought Mintex pads for the job).
I have looked in my owners manual and service book for the correct spec brake fluid for my motor, but can't find it listed. Any ideas please? Also do I have to use MB fluid or can I use a reputable make such as Castrol? ( MB dealer 20+ miles away). How much fluid should I buy?
Advice please on any problems I am likely to encounter bleeding system with ABS pump (never done one with ABS)?
Lastly would it be better to pressure bleed the system with a Gunson Eezibleed kit, so that the crud that may have built up near the master cylinder does not move on to the ABS (with possible dire consequences!). I have only ever bled a system conventionally.
Thanks in advance for all the advice offered.
Jimboom.
Jimboom.
