W203 c180 no crank no start
Phooey692007
New Registration
C180 2002 1.8 compressor
Hi guys I've just fitted a used gear selector as had a problem with the car going into limp mode and then lost the gear display on the dash. Fitted new one ok but now the car Will not crank or start checked fuses and start relay all ok. Got car started from starter motor only to find gears were wrong 2 neutrals and 2 reverses ?. So what have I done wrong too fix one thing and cause two more problems
ajlsl600
france
Bit of a guess..brain thinks car in gear so wont allow start.is selector new or used.? Is it same pt nu or modified pt ?
Try battery disconnect shifter disconnect shifter in park .reconnect shifter ,reconnect batt with key out.try again.no luck get any fault codes looked at ..
Sorry just re read yr post..used shifter. Try above if no joy suggest read codes ,look another shifter
machone
w203 c200 estate Aventgarde
I had the car going into limp mode but it was after a differential refit - turned out to be the wrong(very slightly) diff ratio so gearbox sensor only let me have limp and 2 gears.
mattkh
England
A160 W168 1999 1.6
.......So what have I done wrong too fix one thing and cause two more problems
Did you disconnect the electrics when replacing the shifter/selector, i.e. key out of the ignition?
What position was the shifter in when you removed the old one?
Did you have the shifter in the same position when installing the new one?
