punkieys17
- Jun 26, 2007
Hi, my wife's C200K estate has developed an annoying fault. It falters when idling and threatens to stall. Its done 130,000 miles.
The engine light lit up and merely reported a misfire on cylinder 1. I cleared the codes to see what comes back - it occassionally reports a problem with the throttle body - but its occurance is less often than the car is logging the misfire.
Today I have swapped the coil pack and spark plug with cylinder 2 to see if it moves.
Over a year ago I checked and found the car did have the oil from the camshaft sensors problem and I fitted a new down stream sensor, cleaned the loom, fitted the intermediary loom fix and checked the ECU end which was completely clear. It was not exhibiting the problem then - luckily I read the forums so reacted before thre leak was too bad.
What I did not replace at that time was the upstream sensor - is this a posibility? I had purchased a NGK OZA659-EE24 but when I went to look today I am sure the wiring attached is too short.
So any input on what might be contributing to the problem would be appreciated and a secondary question is where is the connector for the upstream sensor please - I have traced the wire from the upstream sensor and it disappears around the back of the engine above the transmision - where does it actually clip?
