W203 CDI - Replacing Thermostat - Help!
wullyuk
I posted a wee while ago regarding the replacement of a thermostat and received the worksheet from Malcolm (thansk again).
Now my question is what tools did everyone use to get at the bottom right hand bolt, is there a requirment for a flexible shaft on the socket set?
Does the oil filter cover require to be removed to gain better access?
If it had to be removed,it would be mentioned on that job sheet
W
wullyuk
The thermostat is held in by three bolts, it is the right hand side bolt that is a bugger.
If the oil filter cover looks easy take it off,you may need a new gasket to re fit it
Xtractorfan
S class
I removed mine whilst changing the thermostat, makes that bottom bolt much easier to remove, dont forget to cover the filter opening..kitchen roll/towel.. just in case something drops down...
Also it allows beter access for removing and fitting the new thermoststat
W
wullyuk
Do you need to replace the gasket as Malcolm mentioned? Did you use the correct tool for this?
fuji0030
New Registration
A easy home improvement do it yourself project and save up to 30% on your bills by replacing your temperature sensor.
Welcome fuji to the forum :D
I think that you can change it without a special tool
felloffajetski
can i have the diy instructions for thermostat change please on a 220 cdi 2001, thanks
po§§§§§§§§§§§§§§§§§mail.com
I have sent it you can edit out your address now
I have sent it Bill,, you can edit out your address
rajenpandya
1999 C220 CDI thermostat replacemnet procdure
Could I please be sent the procedure as well, Thanks
oilit
Gloucestershire UK
w204 Mercedes, VW, DB9 Volante, Defender 90 50th Anniversary, & Landrover 88"
i have read a number of the posts with regard to thermostats, and my W203 C200 kompressor is struggling to get up to temperature - after 1 hr on motorway it seems to sit at max 60 degrees, and teh heater performance is cr**. I have ordered a thermostat in the hope this fixes it - and i have checked the settings menus and i have no option for heating control as described on a few threads.
Any other ideas or does everybody think this is likely to be the culprit.
It will be the thermostat,,I can send you the fitting instructions
oilit
Gloucestershire UK
Yes please that would be much appreciated! Email is jeremy_nicholls(at)hotmail.com obviously removing the brackets and contents and replacing with @ (!!)
