W203 Mercedes Recommended Alloy Wheel Size
DMK/Happy
SE / Coupe / 2003 / C 220/CDI/A
Searching for 4 alloys on Ebay for the W203 c220 s coupe.
I need the Mercedes Benz recommended approved wheel size for this model.
Research and advice very much appreciated.
Really important I orded the approved Mercedes Benz wheel sizes.
mioba
Nottingham and Köln
Ask your dealer ?
Look in the manual?
So yours doesn’t have the correct/approved size at the moment ?
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
You can use all the wheels in this link. Click on any one to see the wheel spec, scroll down for recommended tyre size.
DMK/Happy
DMK/Happy
Seems 17 inch rims are the correct size , could I go to 18 inch seem to be more on offer after I had a search? Thanks everyone for advice.
JBell
Torquey
C350 CDi Estate (GAD Edition)
Are you after genuine MB wheels of aftermarket ones??
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
17's are a good choice cheaper & more choice of tyres than18", & a better ride.
I have 18" on both the E class & SLC, but 17" winter wheels. I prefer the ride on the 17" particularly on the SLC.
DMK/Happy
DMK/Happy
I'm open to advice here .
DMK/Happy
DMK/Happy
That is a really interesting trial example.
JBell
Torquey
On my W203 I had 8x17" ET35 all round fitted with 225/45 R17 front and 245/40 R17 Rear tyres, no issues at all
DMK/Happy
DMK/Happy
DMK/Happy
DMK/Happy
I also have 225/45 R17 (Crossclimate+) on my S203.
Great tyres IMO.
Interesting proven trial history,at the moment 225/45 R17 front and 245/40 R17 Rear are fitted on the C220 S here. Thank you.
AnthonyUK
Alton, Hants
C240 estate 2002
Shame that Crossclimate are not available in 245/40 R17 which appears to be a particularly German size otherwise I would have gone for that too.
DMK/Happy
DMK/Happy
I had the alloy rim width checked at the tyre shop 8.5 J rear 7.5 J front hence the difference in tyre sizes,,245/40/17/8.5 J rear,with 225/45/17/ 7.5 J front for the C220 S recommended spec. ..
AnthonyUK
Alton, Hants
C240 estate 2002
Yep, it is the recommended size. A 225/45 does fit though and is a permitted size. The actual difference in tyre contact is not worth worrying about at around 8 sqcm and is still around 20 sqcm greater than the 205/55 R16 that were fitted as standard on mine.
17" are normally fitted to clear the 'sport' brake callipers on standard models or for cosmetic reasons :D
Unless you want something specific, best to stick to those recommended sizes.
Mr Greedy
Leicestershire
E350/2011/OM642 265bhp
I had the 225/45/R17 all round on my w203 coupe.
I really liked not having a staggered width set up as it meant at new tyre time, I could rotate the tyres and always put the new tyres on the slowest wearing axle. This means the heaviest wear gets taken out of the oldest pair of tyres, and that means you don't have a set of old tyres sat on a slow rate of tyre wear axle for 10 years.
Some say you should always put the new tyres on the back for safety, but soon those new tyres will have less tread than the old tyres on the front axle. So in my view that is less safe as you are retaining old tyres for a long time. Unless of course you rotate the tyres every 1,000 miles to get even wear across the two pairs, but who can be bothered with that? Not many.
JBell
Torquey
Michelin, Pirelli and GY say new on the rear with a "square" set up so there must be something in it :rolleyes:
Mr Greedy
Leicestershire
Yeah, sorry, wasn't very clear.
Most cars will wear most heavily on tyres on the front, and in those cases, new tyres on the back is the right move. So new tyres on the back will absolutely be correct most of the time.
But if for whatever reason you are in the minority and get heavier wear on the back (and you have a square setup), my personal choice would be to put the new tyres on the slowest wearing axle (which would be the front in the hypothetical example I was trying badly to make) so that you don't continually put new tyres on the same axle and have old tyres never moving on the slow wearing axle.
In reality, I've seen a lot of people with front wheel drive cars needing new tyres on the front (obviously the heaviest wear) and they end up with 10+ year old tyers on the rear axle and then a blow out on the motorway. In that example, I would move the older less worn tyres from the back to the front, and then new tyres on the back.
OP, really sorry for the slight derailment of the thread.
I was simply trying to highlight the benefit of a 'square' wheel set up, that being you can rotate tyres come new tyre time.
