W203 o/s headlight shaking
billos
Hi - I'm about to get MOT'd on a 55-plate C220 CDI Coupe Sport Edition - but the headlight on the drivers side is shaking. Mechanic says the grey plastic bit that stretches from headlight to engine frame is broken and needs replacing - as this is the main component/part in keeping headlight secure.
I phoned MB but parts dept. there are clueless. Do I need a new headlight? Or can the grey plastic part be replaced at all? Headlight part no is A2038203461 but don't want to fork out £200 as headlight works fine.
Your help is required as car will fail MOT in its current state.
whitenemesis
CLS55 AMG '05
There is a repair part available for those top fixings
A2038203214 about £20
Also the modern adhesives used in the motor body shop will also fix it
B
billos
thanks for assistance...will try MB for part, otherwise onto mechanic ASAP.
