w203 Rough Idel
taffrhys
Hi guys,
I have a w203 - 2003 C Class Coupe
Recently the engine has developed a idel fault. The engine will idel between 800 and 2000 revs on it's own. Does this sound like a vacuum problem?
Sometimes it's aright and idles fine, other times it doing this 800 to 2000 up and down motion.
Any help would be great!
This should be a leak in the inlet somewhere, either a vacuum pipe is split or off, it is air getting in under max vacuum condition, and that is at idle
A
andy@pcd-ltd
What is the first 6 numbers of the chassis number so i can work out what engine is in the car.
I have had this sort of problem and this was caused by a split pipe down the side of the engine
T
taffrhys
cheers willow....it's WDB2034762A
C180K C Class Coupe 2003
Any ideas how I get to these air pipes? Someone told me i need to remove the airbox.
A
andy@pcd-ltd
Hi taffrhys
I take it the car chassis number is WDB2037462a as the number you put does not exist on a mercedes. If is is what i put you have a 271 engine in the vehicle and to me would point to the pipe down the side of the engine. Yeah you would have to take out the airbox but youwill also have to take out the supercharger as well to gain access to it to replace it
Hi taffrhys
The 203 746 does exist and a valid number, and the engine is the 111
A
andy@pcd-ltd
I know that the 203 746 does exist that is why i out it taffrhys had put 203 476 in his reply which would make it a 203 convertible and a 600 engine in it!!!!!!!!!!!!!!!!!
When i put the chassis number into wis or epc it only comes up with a 271 engine
Yes it is the 271 only that was my error
T
taffrhys
Hi guys,
Sorry, yes it is the WDB2037462a willow.
Any ideas if removing the airbox / super charger is a difficult one? I read on anouther forum that simply removing the airbox is all that is needed to get access to the pipe. This is a real pain in the ass! haha,
Thanks for you help guys!
A
andy@pcd-ltd
Removing the air box is not too much of a problem if you have the right tools as there is an awkward clip down the back of the airbox to undo.
What area are you in
Alex Crow
Super Suffolk
can concur, no need to remove the superdooper, and not too hard a job for the competent.
Cole@MBS
www.mbssouthampton.co.uk
And dont bother trying to replace the block clip!!
Alex Crow
Super Suffolk
^totally!! one finds a cable tie will secure the hose adequately ;)
MB Service Centre
Mansfield
www.mbservicecentremansfield.co.uk
A210 E320
Hi, best thing to do before you start stripping things off, somthing i do all the time is, with the engine running on tickover just give a little spray of brake cleaner down the n/s of engine block and you will find the wngine will change its tune and run much better for a few seconds, that will then confirm the usual pipe that splits on these engines.
Hope this helps
Hope this helps
Welcome to the forum MB service center:D:D
