W203 to CLC front/headlight conversion
Felix2711
W203 2007 220 CDI
Hello,
anyone got a idea where to get the pinout for the 14 pin bi-xenon headlights of the 2008-2010 clc? It´s 14Pin connector on each side. The W203 has 3 plugs leftside headlight and 2 plugs on the rightside...
Wis don´t include the CLC wiring, it always showing w203 pinout :(
br Felix
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
Have you checked all the diagrams available on WIS?
I only ask because when I was fitting the towbar to my 2016 S Class a few weeks ago, there are multiple versions of the wiring diagrams for the control module and wiring loom to fuse box (Because the loom supplied by MB is also year dependent and cables need to go into different ports on the fuse box depending again on year etc) , depending on year of manufacture, current equipment etc. If you are retrofitting it is just a matter of working through them to find the one displaying the data you need
F
Felix2711
W203 2007 220 CDI
Yeah I tried all but wis only makes difference in 203.2 and 203.7 - so the clc is 203.741 and so it´s handled like a 4door car... there doesn´t seem to be any wiring plans :( I checked my xenon ecu´s one is 230 part# and one is 204 part# ... I got the w204 wiring plan, but there is can h/l routed to the xenon ecu - I didnt find any can signal on oem w203 headlights...!?
F
Felix2711
W203 2007 220 CDI
If anyone interested how the car looking with clc frontend... basically its w203 fender in the back and the clc front attached...
Gesendet von meinem SM-G960F mit Tapatalk
ROM113
New Registration
W203 C180 /2005/M271
Beautiful, I am inspired. I'll give this one a try.
