W203 when stopped and turn steering makes a clanking/popping sound
Bastos00
Mercedes c220 cdi 2004
Hi once again, I hoping for some opinions from you guys, now I'm having problems when I stopped and turn steering wheel can hear a loud popping/clanking sound coming from the driver side. Already changed the axial joint and tie rod and stopped for 2 3 days but then came back once again
Material is brand new. Brand is Febi
B
Bastos00
Thanks for the reply. I'm confused What spring? I'm guessing not
DSK
CLS 320 CDI, S350 Bluetec
Front suspension coil spring on the strut.
Probably a crack at the bottom or top that you may not easily see compared to a crack elsewhere along it.
AnthonyUK
Alton, Hants
C240 estate 2002
You'll need to get under there while someone turns the steering wheel.
There are many bushes and joints that it could be and 203s are really prone to breaking the springs as they are compressed to around 50% of their unfitted length.
B
Bastos00
Thank you guys I will check and give feedback later
Sorry, your wording made it seem to me that you were fitting the parts yourself. Broken springs often make bongbonbong noises when turning.
B
Bastos00
So I have checked the spring and nothing seems broken and I know now where the sound comes from, it comes from the shaft that connects the steering wheel to the steering column.
  • Like
Reactions: DSK
