Hi guys I wonder if anyone can help me? my 02 c180 front nearside window has stopped working, niether the master button or the one on the door does anything. any ideas?
Hi again i've tried to have a look at it but i cant even get the door card off.I've looked at all the threads on here about that but cant find anything helpful.anyone got any idea how i get the card off?
thanks Malcolm, got it off np had a quick fiddle about
When I try the switch with ignition on I get a click like a soloniod from the black box inside the door so it sounds as if the switch is ok and poss the box, cant test for 12v at the motor cos I havent managed to get to the wires yet, i presume there will be a removeable plug in connector on the motor? there seems to be about 4 wires going to it god knows what they do!
I'll try and have a better look during the week in the mean time any info u can give me on the wiring etc would be great
You could try as in picture below, yours won’t be the same as the one pictured (1994 C180) as yours will have a black box however loosening the four screws and wiggling up and down should get the motor moving,
Contrary to what I say in the picture below, I now believe it is possible to remedy motor failure by dismantling and cleaning the armature and Commutator (where the brushes contact) I did this with a failed motor and it is now working fine HOWEVER the motor was never tested in the car over time so am not absolutely sure how effective cleaning is.
Sorted I think it was just a bad connection on the motor, had to move the cable to get to the screws and after i'd moved it, it work ok, tried to reproduce the fault but couldnt so it seems to be ok. Thankyou to those that helped
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
