W203 Wipers hitting pillar - linkage?
P
psr
I have a problem with the drivers wipers in my C220 hitting the windscreen pillar, especially at max speed. I removed the covers and discovered that a compression washer that holds the spindle in place had fallen off causing the spindle to move up and down. I got this back on, which stopped the vertical movement in the arm, but it still hits the pillar.
The parts man in the local dealer wasn't much help when I asked about a linkage, so I'm wondering what could be causing this. Just the linkage? Is it part 30 on here: http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=203206&M=611962&GA=722699&V2=BE6019&VIN=2032062F235331&CT=F&cat=69J&SID=82&SGR=120&SGN=04
Any help would be appreciated.
