W204 2012 Have the front end opened up - what should I change?
rash.m2k
Lancashire
C220 2012 W204
Hi All,
I have a 2012 C220 Diesel with 165k miles on the clock, I have the front end open, so radiator, intercooler, radiator fan and front bumper are all out.
Now that this gives me plenty of room to work - what should I replace while I am here? Everything on the car is still original, just normal servicing has been done.
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
Thermostat, water pump, oil cooler.
They're all things that have failed and been replaced on mine
Flyinspanner
Ruislip
As CSJ says above, also new auxiliary/serpentine belt.
If you’ve had to take out air con - maybe a new dryer canister.
Give the cores on your rad etc a good visual check, wash, and a coat of black satin to help fend off corrosion?
Dab of copperslip on bolt thread when installing.
R
rash.m2k
Lancashire
C220 2012 W204
I guess oil cooler requires new engine oil too? Or can we do it without?
R
rash.m2k
Lancashire
C220 2012 W204
Ok guys, I have taken the cover off and can see some oil, now bear in mind this is a 165k mile engine with everything still original, seems like oil is leaking from somewhere? Is it anything I should be worried about?
Craiglxviii
Cambs UK
Engine? Get an M156 in there.
R
rash.m2k
Lancashire
C220 2012 W204
It's an OM651 engine. V8 Petrol crazy how much that would cost me in fuel!!
malcolm E53 AMG
Yes the leak needs attending to before it gets onto the serpentine belt and rubber hoses, I see the oil is migrating onto the pulleys already oil and serpentine belts are a no no
Craiglxviii
Cambs UK
Far less than you’d think, and I bet your driving would calm down too- mine did on purchase of my V8!
R
rash.m2k
Lancashire
C220 2012 W204
Where could it be coming from? Oil cooler seal?
