Botsy8
- Dec 15, 2018
- C250cdi AMG sport plus estate 2012
Good evening ladies and gentlemen. I’ve searched through some posts and hopefully you can give me some ideas.
I’m getting a slight vibration under load coming in at 1500rpm and disappearing at 1800ish rpm. Typically it will happen on the motorway while gaining speed back to 70mph if you have slowed to 60ish while staying in 7th gear. It also happens around town but not when pottering on fairly level roads. You will feel it on hillls as it passes through this rev range. The car is a face lift 2012 C250cdi with 76000 miles.
It’s already had a torque converter under warranty. I had the engine and gearbox mounts done by an independent but they were not genuine Mercedes items. I think they are lemforder.
Does anyone have any ideas where to look next or should I have fitted genuine mounts. Thanks.
