W204 C180K wiring Diagram needed
stubax
I inadvertently shorted the interior fan feed wires whilst installing a power supply, thought it was just change the fuse but none listed. Does anyone have any ideas or a suitable wiring diagram? Could it be a relay, the climate panel is functioning normally but the fan doesnt run.:confused:
startech
if you can post the chassis number i will have a look and see what i can find
stubax
Chassis number
WDD20404*******- Be great if you could help. Thanks:p
startech
the wiring diagram that i came up with shows a fuse in the interior fuse box F34 at position 119 it should be a 7.5 amp see how you get on if it is not there then i will try again.
stubax
Thanks for the effort Startech, however on the fuse chart supplied with the car it states fuse 119 is in the dash fusebox (fuse 119 is listed as rear A/C), however my car doesnt have a dash fusebox, at least not where the owners manual says it should be!
Tel: 020 8863 9233
