W204 c250 cdi injector issue
Gulbaz
Mercedes c250 amg sport plus 2013
hi guy I’m new I’m here just wanted to ask anyone if they’ve had the same problem as I have my car is a 2013 c250 Cdi om651 the car smokes white heavy smoke all you can smell is diesel from the exhaust once car car is warm it all disappears the fault code I’m getting is p0266 which is cylinder 2 misfire but I’ve changed the injector and coded it but still same problem in cylinder 2 even if I swap the injectors around and code them in still cylinder 2 has the problem what can I do I need the fix for the problem surely someone has had this problem sorted
Gazwould
C250 CDI
Got to be there wiring to injectors ?
Uncle Benz
West Sussex
Mainly Mercedes
I think I’d do a compression test when cold as a first step. Check the fundamentals are good.
bembo449
gainsborough , lincolnshire
as above or have the injectors spill tested to see if they are leaking off too much , then its refurb time
G
Gulbaz
Thanks guys I will get the compression test done today and will post back and Share With you guys
G
Gulbaz
My injector part number is
Delphi
A6510702887
Is this the right injector that should be in my car it’s a 2013 c250 cdi also compression test will be conducted tomorrow as mechanic was too busy
John Laidlaw
Wirral
Land Rover Discovery 4
Certainly starts with 651, a lot of OM651 injectors failed around that time and were replaced under warranty (mine were as a precaution)
G
Gulbaz
Hi guys sorry for the late update but had the compression test done and cylinder 2 compression was down and the mechanics say it’s either the piston ring or Conrad bent anyone no how much would this cost me to get done
Frontstep
T210 320cdi
No one could really say until it's apart but it won't be cheap.
Uncle Benz
West Sussex
Mainly Mercedes
Well done. At least it saved any more messing about with injectors and stuff.
