Rick4495
- Oct 16, 2018
- C class estate/2010/250cdi
Hi all,
I have changed the fuel rail on my car, and have reassembled everything, but am having trouble getting the car started again.
I have tried cranking the engine but made the mistake of stopping then starting cranking again . Apparently this will cause the pressure to dissipate which brings me back to square one again. Tried this a few times the engine started cranking slower and slower so before I fully emptied the battery have removed it from the car and put it on charge overnight.
So how long is too long when cranking the engine to purge air from the system?
Haynes reckons no longer than 10 seconds to prevent the starter burning out but some other posts have said to just crank it for ages.
Also I have bought a can of easy start as another post mentioned to use it as a last resort. Do I have to open the air filter up to get to the inlet or am I ok to just spray it into the inlet by the bonnet catch?
Thanks in advance .
Thanks in advance .
