W204 C350CDi - Battery goes flat intermittently
Sbloxxy
Northumberland
The car is a 2009 W204 C350Cdi and a few weeks ago, the battery would go flat overnight for no obvious reason. After a proper charge up, it would be be fine for perhaps a week or two - and then would suddenly go flat again. The car is used pretty well daily and has been used quite a lot over the last few days and then this morning, its flat again. I think if it was a persistent and constant drain, it would go flat regularly. But it doesn't- its just every now and then.
One thing thats concerning me is that a few weeks ago, I had the infamous EIS/ESL problem. Eventually this was traced to a faulty ESL (Electronic Steering Lock) motor and this was replaced by an emulator. It might be my imagination but I reckon thats when the battery drain issue started. Is that possible or am I clutching at straws? Has anyone else had a similar intermittent battery problem? Any ideas gratefully received.
malcolm E53 AMG
Is it the original battery and have you checked the voltage it should be 12.6V or there about, strange things start to happen when the voltage drops below 12.2V MB electronics do not like low voltage
