moj91
- Jul 12, 2013
- Location
- Northamptonshire
- W213 E400d-T, W204 C250CDI-T, W220 S320CDI (AMG Kit), W168 A170CDI, W210&W124 OM606...
Good Evening.
From almost new I've had my W204 C250, with the 18" AMG IV wheels. I've always suffered severe outer shoulder wear on the front 225 tyres. (Recently exacerbated by failing bushes).
I've had the offending bush(es) replaced with genuine parts, and the alignment adjusted.
Now, having always had issues with the front tyres chewing out the outer shoulders when the middle 3/4 tread area has 4-5mm tread life left, I have come to the decision to try to improve the situation as I am wasting good tyres, and now need new ones again to replace the worn shoulder ones. I've seen other W204's with the same size wheels and they all also seem to suffer the same poor wear characteristics.
The front wheels are 8Jx18, ET50. I used to have 7.5J x 18 wheels on my old Astra SRi, with 225 tyres and, driving that hard, never suffered the same issue.
I get the impression that these 8" wide front rims are better suited to a 235 wide tyre, which will give a 'squarer' fitment of the tyre. So my questions are:
Does anyone know if a 235 wide tyre will fit the W204, with these rims on an ET50 offset (the actual AMG's on 18" rims have a ET45 offset, on a 235 tyre, so according to the online wheel fitment calculators sit 5mm further out/away from the suspension).
And... will fitting a wider, thus 'squarer' tyre reduce tyre rollover and hopefully reduce shoulder wear?
...I don't fancy ordering a pair of 235 premium tyres to find they catch/rub.
Or does anyone know of any other solutions? I am aware that MB have their cars set at a quite high positive camber, which as far as i can tell does not help the situation.
(I've trawled the forums for the same questions and answers but I'm struggling to find info - sorry if this has been covered before, which i suspect it has!)
