W204 power loss
BVF
Staffordshire
C200 CDI Sport W204 Tenorite Grey
Hi all. I have a 59 plate C200CDI that suddenly loses power while cruising at Motorway speeds. This lasts a few seconds, then all is ok again for 5-10 minutes then it will happen again, but not EVERY trip. Bizarre.
There are no indications on the dash or service display to say anything is wrong. Its a bit un-nerving when you're overtaking wagons let me tell you!
Only thing I had recently was a bit of juddering on a start up after leaving it for 3 hours. Engine management light came on, but after a couple of revs it ran ok.
The light stayed on for the 30 minute journey following this. I turned it off, took the key out, left it for 5 minutes then started it. The light went out. Ever since I've had the above problem.
Any thoughts appreciated.
Cheers.
grober
Scotland
W204 C200cdi estate
MAYBE A FUEL CONTAMINATION PROBLEM?
B
BVF
Staffordshire
That was my initial thought, so I ran the tank virtually dry then brimmed it with BP Optiwotsit, or whatever its called! 90 quids worth anyway.
Same.
B
BVF
Staffordshire
Hi all.
Problem has now progressed to complete power loss, with the skidding car picture on the dashboard that someone else posted a pic of. I coasted to a halt, key out for a minute, then power came back BUT with engine management light permanently lit.
Any ideas please?!
Corned
East Midlands
2005 S211 E320CDI Avantgarde
Something needs fixing. You need to get the fault codes read. Something is wrong somewhere and as you have discovered, it is not going to fix itself.
The ESP malfunction means it might not be the engine which is actually having the problem. It could be brakes/wheels rather than engine, but you (like the rest of us) will be guessing until you get the codes read.
B
BVF
Staffordshire
Bitten the bullet & taken it to MB.
They reckon there are a number of faults showing on the diagnostic.
A wiring fault being one, which has led to a knackered ecu.
Cutting a long story short, £1615.24!
I hate the feeling of being held over a barrel.
I'm furious!
Corned
East Midlands
Your local indie might give you a second (i.e. cheaper) opinion.
B
BVF
Staffordshire
Trouble with that of course is that I'll void my Mobilo cover etc.
Steve@Avantgarde
Bristol/Somerset
Not for repairs it wont. It is only void if an Indie is servicing your vehicle and even then the money you could save on service could buy a good breakdown cover.....
Nothing stopping you having any repairs at an indie.
B
BVF
Staffordshire
Being given the run around.
Was told yesterday that it was a knackered ECU which would cost £1615 incl the 2.5hr diagnoses and investigation costs.
They left the battery off all night and when they put it back on today the fault has changed to "Fuel temp sensor". (£166.80) with the ECU as a stored fault.
Their 'Technician' suggests changing that to see if it cures the fault. If not, its the £166 PLUS £1255.20 for the ECU!
I'm not convinced the Temp sensor is the real fault and I'll end up paying £166 for a part I don't need.
I feel I'm being taken for a ride. They can't even supply me with a courtesy car as "they have to be booked 3 weeks in advance". I've never heard anything like it in my 20+ years of driving!
Anyone got any thoughts on their verdict?
Do you think they're right?
They seem to think I'm made of money.
grober
Scotland
W204 C200cdi estate
For £166 its probably worth a punt. If that doesn't cure it - time to take stock before spending any more money. You may then wish to consider changing MB agents.
Corned
East Midlands
... or listen to posts #7 and #9....
B
BVF
Staffordshire
Those were my thoughts to be honest.
st4
Banned
Sunny Scotland
1-stephen-taylor.artistwebsites.com
Disqualified driver
Is it common the ECU goes, I suspect its a more minor fault that the £166 will fix.
If not, use another garage, the courtesy car thing is a load of baws and you'll find a place that will treat your custom more seriously, or take it to a specialist in the area?
o2der1
Does anyone know if this was ever fixed..? And if yes how...?
I`m having the very same problem..!
Grey
New Registration
BELFAST
W204 1999 200CDI
looking a bit commmon
my car has started to do this for 4 months since a warranty recall for front airbag activation sensor. is this linked?
