W204 - will not move from "P" parked to "D" drive
MBnewbie123
MBnewbie123
C-Class W204 2008 2 litre
  • #21
So, I replaced the brake switch - that did not solve the problem. None of the fuses seems to be blown. I ordered an OBD unit. If that does not help me, I will leave it into a garage and hopefully they will solve the problem. I will let you know what happens.
mattkh
England
A160 W168 1999 1.6
... I will let you know what happens.
A tip for the future.
When you take a photo of an electrical connector, make sure the colours of the wires going to the connector are in the photo.
The colours of the wires tie up with colours shown on the diagrams of the electrical circuits. This helps diagnose electrical faults.
MBnewbie123
MBnewbie123
  • #24
Hi, thank you for that advice. I have uploaded photos of the wires that were cut. Hopefully, that will assist you in diagnosing the problem. If you need any more information, please ask.
MBnewbie123
MBnewbie123
  • #25
It seems it was a fuse. I had checked the fuses, but not well enough. I used a multimeter and discovered a blown fuse. I replaced it and the problem was solved.
Regarding my most recently posted photos, does anyone have an idea as to what caused the problem?
onefortheroad
uk.
Id hazard a guess that the cutters you used shorted something out and blew that circuits protection fuse.
ajlsl600
france
mattkh
England
A160 W168 1999 1.6
Many thanks for the photos. I do not have a hard copy of the wiring diagram.
I am glad to note that you have located the blown fuse.
Normally, the German car manufacturers use a
BROWN colour wire for letting the current go to the negative (-ve) terminal of the battery via the metal body of the car and a
RED colour wire to show that it is bringing power from wherever. So the red wire is what you may call LIVE.
When you cut the cables, did you cut one wire at a time?
MBnewbie123
MBnewbie123
  • #31
MBnewbie123
MBnewbie123
  • #32
I cut them with a craft knife, so they were not cut by a wire cutter or scissors, etc. So, they may, unintentionally, been cut one at at a time. Bear in mind, that they were simply connected to the phone cradle that was in the storage compartment between the front seats. I know very little about electrics in a car (or anywhere else), but, what is the difference between cutting through the wires and simply disconnecting them in a conventional way. The wires were going nowhere - their destination, at one end, was an electrical dead-end as far as I was concerned. The reason I did not disconnect them in a conventional way was that, initially, I could not get to the connector clips (they were under the lining of the storage compartment). So, I suppose I am asking, would disconnecting them in the conventional way have had the effect of causing a problem with shifting the gear stick?
onefortheroad
uk.
Reminded me of that movie the hurtlocker. :)
EmilysDad
Bury Lancs
ML350
If you popped a fuse somewhere, you obviously shorted across at least a couple of wires. Unplugging would have been your best bet. If you found a spare cable at home, would you just cut it off?
If you know little about electrics you might have better to leave the cradle where it was or get someone else to do it for you ;)
