W205 suspension conversion from EDC to non-EDC
w2052017
New Registration
C Class W205 C250 4matic
Hello, I have a 2017 Mercedes-Benz C Class W205 C250 4matic and I want to upgrade it's suspension setup, going from the factory electronic controlled suspension to an aftermarket static variant of the Bilstein B12 kit (dampers + springs). Ther reason I'm doing this is because I want a proper sport suspension with better handling with smaller wheel gap than the original one that came on the car. My only concern so far is if I will need an EDC deletion kit, as I'm going from an EDC setup to a non-EDC one, and I'm not sure if I will get some errors after upgrading. Do you have any knowledge if I will need a deletion kit, and if that's the case then what model should I look for? Thanks.
www.W140.co.uk&www.r129.co
