drivinggod09
hi im having a problem with my clk 230 komp on an x plate 2000 the manifold cracked as seems to be a common problem on these models which in turn eventually activated the engine managment light i drove it for a few hundred miles like this as i knew the fault and planned to repair myself on leave, fitted the new manifold with gasket from merc dealer which made it sound proper again had it plugged into computer at local independant workshops came up as oxgen sensor downstream of cat so replaced this light came on again with fault code oxygen sensor upstream of cat also replaced this on but the light has come on again with the code oxygen sensor downstream cat convertor but its working because it says so on the computer im wondering if maybe the cat is doomed as its started making a slight rattle under load when pulling off or could it be that the fault has been stored due to the length of time i ran it in the ecu and it needs restoring back to factory settings can anyone help as this orange light will soon be the death of me
