I had the drag link replaced and an alignment done a couple of months ago. Then this issue cropped up within the past month... The front left loses grip on slow right handers and almost ploughs straight on when it's wet. It makes a noise as though the tyre is being dragged.
I thought it might be related to worn bushes, so I've just had the upper arms and ball joints replaced, and powerflex bushes fitted to the lower arms. It hasn't solved the problem.
Wiggling the steering quickly produces a knocking noise. The steering box bolts have been tightened, and everything that could wear has now been replaced.
On jacking the car up it does appear that there is play in the steering. But it's not the drag link. Theres nothing left to replace now other than the steering box.
My hypothesis is that the play in the steering box is causing ackermann to be thrown off. But what do I know...
