W208 Command upgrade
Stafford71
W208 320 Elegance
hi i have a 2000 W208 with the Audio 10 cd player
looking to upgrade to the command headhunt, ive been doing a bit of research, and it looks like it may be plug and play
can anyone confirm?
regards
mioba
Nottingham and Köln
command online will be along to answer I am sure. they are the gurus
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
No, it’s a lot more than that. As I understand it, Comand units create much more heat so need specific cooling fans and ducting and the whole process, while, doable, is complex. Speak to the guys at https://www.commandonline.co.uk/ for more info. @Alfie
Alfie
Surrey/Cotswolds
www.comand.co.uk
On a W208 it is pretty much plug and play although you will need to find the speed pulse and wire that into a loom adaptor. Plus a GPS antenna.
We have the loom adapters and also a genuine W208 comand unit that came out of a channel islands car that had only covered 17,000 miles.
Email your full vin number to sales@comandonline.co.uk and we can quote you.
Stafford71
W208 320 Elegance
Hi emailed in earlier and received a quote from mark, however he mentioned coding to the car in the quote. Can you confirm please
Sent from my ONEPLUS A6003 using Tapatalk
Alfie
Surrey/Cotswolds
www.comand.co.uk
The fibre ring should be properly coded on the comand and also the instrument cluster will need coding to display the navigation instructions.
www.W140.co.uk&www.r129.co
