W208 fog light bulb
Stafford71
W208 320 Elegance
Hi what type of front fog light bulb fits a 2001 clk. Reading through the manual, I see the front headlight indicator types, however not the front fogs.
Off topic, is there a known mod to add a 2nd fog light to the rear lights, as mine currently only has 1
Regards
Stafford 71
Sent from my ONEPLUS A6003 using Tapatalk
EmilysDad
Bury Lancs
ML350
Most MBs have just one fog light on the offside ..... apparently fitting one on each side would be confused with brake lights :rolleyes: :rolleyes: (though other manufacturers manage to fit one on each side)
davemercedes
Glos
One fog light at the rear is rather stupid if you travel in Europe frequently. I had a Renault Espace and on a foggy night I was followed by a colleague - who pointed out that from a distance it placed my apparent "offside" on the wrong side of the road. Both the rear lamps already even included a fog light and it my Renault dealer charged 1/2 hour's labour to connect it so they both worked off the foglight switch.
I think my S203 rear fogs light up both sides ?
mattkh
England
A160 W168 1999 1.6
Regards
Stafford 71
Check the opposite side rear cluster, you will find that just the bulb is missing.
Stafford71
W208 320 Elegance
Thanks, I'll have a look.
Any info on front fog bulb type. Thanks
Probably H1 but without removing it cant be sure.
Are you sure it's not in the book?
Stafford71
W208 320 Elegance
I've read the owners handbook a few times now and all except the front fog are listed, I've ordered some H1 as worst case scenario can be used on the wives car
Thanks for the reply
EmilysDad
Bury Lancs
ML350
That was not the case with my R Class. There was a bulb in each side, but the nearside bulb was only used as a 'back up' lamp in the case of AN Other bulb failing.
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
There is an Osram bulb app available. i have it loaded on my iPhone, useful for knowing what bulbs the family cars take. Shows standard, longlife and upgrade bulbs for the vehicle application you enter. Worth a try. Just google Osram bulb app.
