W209 CLK Bi-Xenon problem
Chiefgroover
My RHS dip beam usually doesnt come on. Well not for some time, I have gone for days without it working then all of a sudden it works? when it comes on it stays on as long as i wish. Once switched off again and left a while I am back to square one. Seems that the problem is with the triggering? Anyone had this problem? and know the cure?
whitenemesis
CLS55 AMG '05
Does the main beam work on the RHS? Bi-xenons operate on dipped and main beam.
When it does not come on, lightly tap the the igniter box and the lamp to see if it is a poor connection, it could be the lamp
whitenemesis
CLS55 AMG '05
Yes the main beam is fine thanks.
Don't confuse it with the halogen bulb. Bi-xenon set-ups use the xenon for dipped beam using a metal shield to prevent dazzle, then the unshielded xenon plus the halogen for main beam.
If the xenon is firing on main beam but not on dipped, expect a problem with the control / ignition module.
Not sure how this would work as it is only the shield that moves for main beam....
C
Chiefgroover
The main works but when the dip is out, its out and doesnt work at all.
will try the connections next.
