w209 clk factory phone kit
Status
Not open for further replies.
ozzies
Just swapping my 208 clk for a new model and it has the factory fitted hands free phone kit .ther is no phone with it but the nokia cradle part no. A2098200751 is fitted.
the previous owner used a 6220 but I want to use its replacement the 6310i will this physically fit the cradle and interface with the software on the satnav command and the steering wheel ok?? with nothing to do.
many thanks for any replies, Ian
O
ozzies
ok teky I am probably being stupid here but I don,t understand and the link you kindly provided just gives me a general spec. of the phone which I already know help?
teky
UK North East ish
it was mainly to point you in the direction of nokia so you could at least check if the kit in your car was compatible with your phone me not being into the phone thing in cars dont know much about it and dont like mobiles in cars sort of thing :wink: it was just a nudge in the nokia direction rather than guess
O
ozzies
ok thanks teky, anyone else out there who can help me please!
Arnie
London
You need to find out if the two phones are of the same hardware/software family. One way to check is to look if the connectors at the botom of the phones are the same and also see if Nokia offered the same kinds of modem, adapters and, for example, PC software for the two phones.
If so, it will get you past the first hurdle. the other one is to see if they are the same size and fit for the cradle.
O
ozzies
ok thanks thru error the phone fitted was 6210 not 6220 as prevously stated so all holds true for 6310i physically same etc but i have heard the mb command will not function and needs new module or something and will cost big bucks
ralph
London
I had a factory fitted 6210 in the armrest of my W209 which I have DIY upgraded to 6310i. The PSE interface module that you will HAVE to upgrade is located centrally between the back seats and the spare wheel. Reasonably easy job.
Now the bad news. MB charge £238.50 (incl VAT) for the PSE module, A 203 820 51 85 which is the current one for a 6310i. Although almost physically identical (reasonable rather than perfect physical fit to the existing cradle), the 6310i requires this updated PSE to function.
Occasionally you can find them on ebay for about £100, usually from Germany, but be warned, stick to the above model number as many older ones are for sale (discards from others who have upgraded from 6210's or older).
Can't see any on ebay at the moment. Recommended search words -Mercedes Nokia Interface.
This is a link to an OBSOLETE one. I have included it so that you can see the unit & the type of listing. DO NOT BUY THIS ONE.
http://cgi.ebay.co.uk/ws/eBayISAPI....;item=2482089064&rd=1&ssPageName=WDVW
There has recently been some talk of UHI (Universal Handy Interface) and Bluetooth functionality, but that might only be for just appearing ModelYear2005 W209's which have been upgraded to DVD Comand and a completely different Can Bus system (MOST replacing the older DB2). I would suggest discussing this with MB and take this route if possible. The 6310i is getting 'long in the tooth' (pun). Recently Nokia announced it's withdrawal, but seemed to have retracted that for now. However it is less than clear if they intend a family upgrade path for the 6310i. This decision is an important one as MB's (hopefully) last longer than Nokia's.
O
ozzies
many thanks Ralph that just about solves it for me best wishes,Ian
Status
