W209 CLK270 CDI smoky on acceleration
Angeloj
Norwich
W209 CLK270CDI Avantgarde
Hi guys, just wondered if these engines are notorious for chucking out a noticeable amount of fart on heavy acceleration and when overtaking etc? Mine has done 118k miles fully serviced and running fine, but when I look in the rear view mirror I do notice a cloud of smoke!
Any ideas?
Thanks Jono
sfc501
Any ideas?
Thanks Jono
Mine does the same and I feel embarressed by it, after all it's a Mercedes..
Angeloj
Angeloj
Norwich
That's my exact sentiment!!!
oigle
members.optusnet.com.au
Highly likely to be a malfunctioning EGR valve. Quite common. Why not consider doing an EGR delete? Very good mod.
Check out the post on the subject by dieselman.
Angeloj
Angeloj
Norwich
Oh ok, what does that do?? I guess I'll have to find the link unless you know where it is??
Angeloj
Angeloj
Norwich
Just found the post! Very interesting reading but will have to have a think first!!
Angeloj
Angeloj
Norwich
My only concern would be the increased warm up time because its only 10 makes to work and it takes long enough as it is !
Angeloj
Angeloj
Norwich
I had mine replaced in June so all is well! Just got to find a coolant leak I've developed!!
David Nock
South Yorks
CLK/2009/320CDI
Yes, my 2004 270 CDI CLK did exactly that even from demonstator miles (bought at 5000 miles).
Driving into sun with a hot engine and then overtaking, look in the rear view mirror and cor blimy!
Typical characteristic of the engine I was assured. It cleans itself on longer runs.
oigle
Don't believe everything you are told. If you do the egr delete, the smoke is virtually a thing of the past.
