I'm new to MB and recently bought my first call, wanting to change the head unit all went well and took a switched live feed from cigarette lighter. SRS flagged up and I read this was common for not disconnecting battery, school boy error, so I plugged in my obd2 cheap android reader to clear it. It didn't work now I have an SRS error, traction control error and worst still the fan now runs after the ignition is switched off, this only happened when I try the obd reader, which has been great on my other cars. I think it's blow or confused the ECU?? Problem is battery is flat in a bout 10 minutes, it needs replacing anyway but any advice? The fan stops as soon as the ignition is on but sounds like a jet when off. Thanks
