mr. shr
Hi All,
A friend of mine has an issue with his W209. The steering cowel behind the steering wheel is loose and rotates a good few degrees in both directions. When you operate the indicator stalk, the whole assemble moves with it.
I took the wheel off and the main module unit to reveal the upper part of the steering column.
With all this removed, I found that the metal fitting (that sits right at the top of the shaft) rotates by hand (whilst the shaft remain stationary). I couldn't see a way of tightening this piece in anyway. To me, it should be tight, with no movement at all.
Anyone know why this bit would be moving?
I fear it will need a new steering shaft.
Has anyone here come across this before?
Thanks,
shr.
Thanks,
shr.
