W209 workshop manual
Angeloj
Norwich
W209 CLK270CDI Avantgarde
Hey guys,
I'm looking to swap over my centre console bits from the old style audio 10 to audio 20 plus new hazard panel and climate control switches all of which I've sourced from eBay, however I've no idea where to start in removing the old and refitting the facelift gear. I've looked for a Haynes manual but to no avail.
Any ideas on what to do or where to get one?
I've got I 2004 CLK 270CDI.
I know KillerHERTZ recently underwent this upgrade, but need some help!!
Thanks jono
I will have the information that you need
Angeloj
Angeloj
Norwich
Oooh lovely!! You never cease to fail us Malcolm!!
Just pop your email address up and you can edit it out when you get them
Angeloj
Angeloj
Norwich
Thanks Malcolm;
7 things sent, see how you get on and you can edit out the address
Angeloj
Angeloj
Norwich
Thanks for those Malcolm, much obliged!!
thefast1
Hants
CLK 350 Sport Cab
Would any of those instructions include how to remove a command unit, if so, could I also get that from you please Malcom.
OK and sent and you can edit out your address :D
thefast1
Hants
CLK 350 Sport Cab
Thanks Malcom, is there a seporate instruction to remove the top and bottom panels please (top row of switches and heater controls) before you remove the command as that is the issue for me, not knowing if there are clips that can break.
I have sent 2 more, are these OK, if not I will print off more this evening :D
Angeloj
Angeloj
Norwich
Would you mind sending these to me please Malcom? Not sure if these are part of your original email?
I need your Email address and I can send all 3
I have sent a load of things if they are not right I can send tomorrow, you can edit out your address as I have it now
Angeloj
Angeloj
Norwich
  • #19
Hi Malcolm, hope you're well? You don't happen to have diagrams for the injector seals/injector pump for a W209 270cdi do you? Mine need replacing!
Thanks Jono
