Fallen Angel
New Registration
- Feb 19, 2009
had bsp/esp abs light come on while driving(also had engine management light on)the cam position sensor was leaking oil-I fixed it by pumping sealant into it (after de-rivveting it)-was told a load of bullsh** that there was a "modified" type by a "merc" specialist-£150 for a new one from the stealers-then went to start the car later-it was dead-ignition key was accepted by the lock(double click)-although one of my keys are f**ked and get no response.The dash lights up-showing NO malfunctions(apart from the engine management light).....called out break down service-he found NO power at starter solenoid-but started the engine by Jumping the terminals.(with ignition key in ignition)-but I couldn't get gearbox out of park(10 mins later on your forum- I found a fix)-engine runs but seems that the gearbox is stuck in 2nd(enough to get me home-at a miserable 40 mph).......was thinking it may be the EIS?-but don't know where to find it-or how to change it!-any help would be appreciated!-I'm a newby and hope that this info would get someone home (even if the EIS is f**ked)
